Casual_Reader
- Sep 2, 2015
93 - basic 2.3l - rwd - xlt - 168k miles. I love this truck.
I lost the pins that go into the wheel cylinder
Looked everywhere.
I've also been looking online for hours and they seem impossible to find (unless I want to spend over $100 for ford original wheel cylinder that supposedly comes with the pins) Pin specs aren't listed on any new parts.
local yards only hold more recent vehicles... this is a 25 year old truck.
any Ideas? other than making my own to match the ones on the other side?
For those of you wondering "How_in_the_holy_heck do you lose parts you need?" (I know I would be):
Well, what happened was... I knew the wheel cylinder was leaking, but also knew the drum and shoes had plenty of life so I got a wheel cylinder and thought it'd be a somewhat easy hour to replace.
I took the drum off and pretty much everything was trashed... the cable had dissolved from the brake fluid? Springs were in pieces, etc. It was late so knew it'd carry over to the next day after getting a load of new parts... including a new brake line. (3/16ths tube nut frozen in the 7/16ths brass adapter to the wheel cylinder... no room to spin the loose wheel cylinder to get it out.) Even after breaking the line and getting the adapter out, it was a struggle to get the 3/16ths tube nut out of the adapter - unbelievable. That new AGS Poly Armour Brake Line is great stuff, btw.
I left the trashed parts on the driveway under the truck overnight... including the pins. When I went to retrieve them... they weren't there. Everything else was. Lug nuts and tools were put in a clean box and placed in the cab, but the pins weren't in that box either. I looked everywhere... even hosed off the drive into a pile and sorted through it by hand. Nowhere to be found... not in the cab, not in the bed, not on the drive. I threw nothing away.
A rabid Ford hating raccoon that doesn't care how shiny something is?
Makes me wish I had a security cam on the drive...
