Wheel Clearance
crawfost
Hey guys, I was just wondering how much lift I will need to run 33" Tires? Thanks alot guys.
You need to give year and model.I do believe there is something in tech library.I don't know for 2wd though.
3 inch body lift should do it with no problem. The kits aren't very expensive either, maybe $250. Or if you want a little better performance, go with a suspension lift. Fabtech makes a nice 5.5" kit. But don't forget that you'll want to change your gears too. You'll have trouble turning those big tires.
