vbrad511
A few days ago I noticed my Ranger (97, 4wd) tracking a little strange. I pulled the front wheels and found the packing nut on the drivers side about 3/4 of a turn loose. Passenger side not quite as bad. History...back in december I installed new rotors, pads, and bearings. I've always just tightened the packing nut snug, then back it off a touch and pinned it. I didn't know the torque procedure then... 35lbs, then backed off 1/4 turn, then torqued 16 in/lbs. So yesterday I disassembled everything, cleaned it all up, repacked the grease in the bearings, and went and bought the big funky socket for the packing nut. Torqued as instructed, put it all back together. With the wheels on the truck, but off the ground I've got about 3/16 of an inch movement if I grab the wheels at 6 and 12 or 3 and 9. It's the hubs/bearing play, not something in the suspension, you can see how it's moving. Is this 3/16 something to worry about? What do i do to correct it? Really don't have the $$ to replace the rotors and bearings again.
Thanks....
Thanks....
