Wheel Bearing Torque Spec
Lethbridge
AB - CAN
Vehicle
Drive
Hello
I am looking for the actual torque spec for the front wheel bearings spindle nut. 2011 Ford Ranger 2WD
Please do not reply "tighten until..." Looking for the actual Ford spec.
Thanks
I *believe* it's 12 inch lbs.
Disregard...
From the haynes manual:
1)tighten to 17-25 FT lbs while spinning the rotor around.
2)backoff 1/2 a turn
3) re-tighten to 18-20 INCH POUNDS
That sounds pretty light. Anyone have a Ford service manual.
Just to make sure. - your looking at 2wd spec not 4wd hub spec?
I thought the Ranger went to unit bearings in 98?
Hello
Thanks
I have the 3 volume set of 2011 Ranger Ford factory service manual set.
It's not really a final torque. Its a sequence of two torques while rotating the rotor (calipers removed) as was described in post #2. See photo below from the manual.
I thought so too the first time I did the job myself.. but.. I'm not smart enough to be an engineer. Thankfully the ones Ford employs ARE.. for the most part anyways.
Nah they kept the old school jobbies right up until Ford started the ranger hiatus in 2012.
Event Coverage
TRS Merch
