Rockstar04
Wheel and Tire Guidance Needed
I have been doing some research on the forums and the Tech Library to replace my stock rims that are slowly rusting away. I think I have what I need, but before I go and drop a ton of money on new wheel and tires I want to make sure I don't waste a ton of money on parts that will not work. I'm not looking for anything extreme, I want to try to stay inside the stock flares if possible and want to retain my full turning radius (no rubbing).
Currently the truck has no lift of any kind, but I am planning on doing some kind of leveling when I install the new tires.
So here are the Wheels I think will do the trick.
ProComp Series 98
And the tires
Wrangler DuraTrac
According to the tire size chart in the tech lib, this SHOULD work with the 1.5"~2" lift in the front from leveling the truck.
Any guidance and input is greatly appreciated!
ProComp Series 98
- 16x8
- BS 4.250 in.
- Offset: -6.00mm
And the tires
Wrangler DuraTrac
- LT245/75R16
- Dia: 30.5"
