Whats wrong with my lights ?
Explosive
Michigan
First day I got my Bronco II, got back at night, drove it around, lights worked, were finicky, but they worked, sometimes they'd cut out but if I messed with the high beam level on the column they would come back, now I only have parking lights and no headlights ? Any suggestions. The night I brought it home was the only time the headlights would work.
Have you checked all fuses yet? If fuses are good, may have a faulty headlight switch or loose or broken wire somewhere.
my 93 ranger had the same prob im waitin on a new switch if that fixes mine ill let ya know
Sounds to me like your high beam switch is bad.
I looked over the fuses, I was also leaning toward the high beam switch, as thats what would cause the lights to come back on when they would go off. Would have to yank it back hard.
mine did that and it was a bad ground on that nut that holds the switch to the dash
I'll have to give this a look tomorrow, I know the windshield seems to have been leaking, maybe it got wet and nasty.
leaky windsheild seems to be a common ranger thing..both of my previous rangers did it and so did my current untill i got mad and threw a new one in it..wet floors every morning is lame.
my windsheld was bad and i think thats what caused my swich to go out but i ordered a new one from lmc and put it in the other day and my head lights work good as new so that fixed mine it may fix yours to the part only cost 27.70 shipped to my door so weather or not it fixes it you arent gonna losse that much money in replaceing it
