What's this??
Thanks for that. I'm sure the tack welds will break first.:dunno: But it's 100% done in those pictures and I am too far into the build to change things.
What's this??
I like it. I do agree on the more support for the turbo though. I may just have to turbo mine.
did you run the 95tm's? probably not with the boost eh?
No I used the 91tm heads. 10:1 would have been too much with boost. Had I not been doing the turbo I would have put the 95tm heads on for sure.
i'll be looking forward to the engine management tech. stuff. did you ever get your speedo gears figured out? i think i sent you a pm?
By the looks of things I'll be adding a couple of injectors to the intake tube. I've already installed a Hobbs switch into the intake that will be used to control them.
Ya I have the speedo thing figured out. I've got a 20T 18T and a 16T driven gear in my tool box. Once the engine is back in I'll swap out the current gear for the 18T.
Ooooh, pretty!
i did a little checking and stock 3.55 is a 19 tooth in both my 91's.
4.10 and 33's i read maybe 1 mph faster than actual at 60mph on several radars.you should try the 20 tooth rather than winding up reading 2-3 mph faster than actual with an 18t.
let me know how it works anyway.
Engine is back in and starting to connect the stock parts. I'm planning to do something different with the exhaust. I didn't like the setup I had going.
What's this??
Reminds me of the exhaust that came on 3.0 4runners....
Looking good!
