Njgcoupe05
- Jun 29, 2011
- Automatic
hi guys I have a 98 ranger 3.0 automatic, I'm having vss issues. I checked my fuses this morning and the #27 fuse(15a) was blown, I replaced the fuse with a new one drove it and the speedo worked and trans shifted fine for about a mile or two then started jumping around again, when I got back home I checked the #27 fuse again and it was blown. The #27 fuse is the- electric shift, backup lamps, daytime running lamps(drl) and transmission control switch. I feel like that has something to do with my vss problem can anyone help me? Thanks
Btw I replaced the vss in the rear already and cleaned the connector plug underneath the driver side but did not use the dielectric
Grease will the grease make a difference with the connection if the connections bad?
