whats the best for the money
2wdmuddin
suwanee, ga
i want to lift my 94 extended cab to fit 30s and look right, but i dont have that much money. i lookes at the front end leveling kit from rough country but is there any other parts i would have to replace?
The only other thing you will have to replace would be the camber eccentric for the upper ball joint, meaning an alignment would need to be done.
i talked to a guy at 4 wheel parts and he was saying i will need new cams and an allignment and cams would be about $257 does that sound right
It depends on where you go. That might or might not be right because I've heard a lot of different things on this forum.
is that with the aliment
get coil spacers and an alignment. I got my spacers for 60$ and an alignment for 44$
I asked several of the places here that I knowthe people who do lift kits and all of them said if you go three inches or more you will need an alignment. For 2 inches of lift don't worry about it unless you can feel some pulling or some drift...this can be form a problem you already had before the lift!!!!
