What years does this intake manifold fit?
booblinker
Richmond twp, mi
I have a factory Ford OEM Intake Manifold assembly. I am looking to sell it since the Ranger is long gone and I drive a Chevy now :bawling:(which BTW broke down last night) Anyways I know it fit my 93 Ranger 3.0, but I can't find anything the tell me all the years it fit. Ford Part # is RF-F27E-9E927-AA. Any help is appreciated.
the 93 3.0 (i own a 93 3.0 a4ld automatic 4wd) has a blockoff plate no egr, but his upper plenum has the throttlebody built into it. i retired my truck because you cant get that part anymore and my throttle blad sticks open beyond 50 percent. just recently purchased a used 04 plastic upper plenum with seperate throttlebody and am going to retrofit it to my 93. according to other members the newer plastic and aluminum upper plenum with the throttlebody seperate will bolt up to the older manifold as an upgrade/replacement. the plastic plenum setup supposedly breaths 15% better than either aluminum units, but is not portable like the aluminum parts are. the lowers plenums are similar, not sure about an interchange there. back to the original discussion, that manifold will bolt up to any year 3.0 vulcan lower plenum, buyer be mindful you cannot seperate the throttlebody assembly from it as they are built as one. if an egr is to be used simply remove the blockoff plate and install the egr to the manifold it is capable of accepting one. id also look into what year taurus 3.0s it can mount to since the engines are the same other than the exhaust manifolds/intake are backwards on a taurus.
