Psychopete
I bought a used Tempo that is in a lot better shape than my red one. Made a mistake when I bought it because it was leaking some trans fluid (pan gasket is leaking), but later I noticed it spewing oil onto my garage floor. Rear main; same problem with my Red one but this one is much worse.
I have pulled the engine out of the car, from the top.
Lets just say that it was not easy, but possible..
Got the oil pan ripped off. Planning on changing the water pump, oil pump, and rear main. The oil is somewhat baked on and cruddy on the mains. Would it be worth while to check the main and rod bearings, with the notion that's it's possible for a small chunk to comtaminate what I am working on? Cam looks decent. Engine ran like crap, but 130~135PSI on all cylinders. Had KOER codes, but I had the FEAD off to replace the harmonic balancer so couldn't run it for long at all. Found lots of vacuum leaks. Deleteing the A/C and vapor canister crap.
Going to check the timing chain slack, but would it be worth while to replace the front seal? A part of me wants to do it right, but the other half doesn't want to spend a lot of dough on this beater..
