- Aug 6, 2007
- State - Country
- GA - USA
- Vehicle
- Ford Ranger
- Automatic
- Total Drop
- few inches
- Tire Size
- ~30"
I'm looking to change from my current 3.43 (IIRC, know it's 3.4 something) to a 3.73 gear ratio. This in on my 1984 Ranger which is currently running 225/70R14 tires front and rear. In the next year or so I'll probably be lowering front and rear 3" and step up to a slightly bigger and wider tire in the rear at that time to fill the gap. I'm pretty sure that 3.73 will still be a good gear for the largest size I'd run, as I doubt I'd go any taller than 28" diameter. What would I gain just from the gear change? I know I want to stick to a stock gear ratio, and pretty sure 4.10 would be to much for my purposes.
I could care less if it's a 7.5" or an 8.8" axle as the 2.8 won't be putting out enough power to damage it. The brakes also aren't a concern as I've alredy got 10" drums and am not planing to move to move to disk brakes any time soon. When I do find a new axle it will likely be a limited slip but it isn't a necessity, just if it's available to me at that time I want it.
Just want to verify this. If I want a slightly wider axle I need to go with a post 92 axle right? IIRC it'll give me an extra 3/4" width on either side? If so that'll be my axle of choice as I want to widen the rear track a little without buying new tires. Should also make it easier to find wheels with the backspacing I need later on without having to go custom.
Thanks,
-Josh
Thanks,
-Josh
