goldxlt
in an attempt to save money i started doing my own work on the truck. today i was checking my brakes out and i noticed that my inner pad on the driverside had uneven wear to it.
the outer pad on the driver side seems to have even wear and alot more life left and the both passenger side pads have even wear however the inner does appear to be thinner then the outer. i was wondering what would cause the pad to wear like this? should it be replaced or can i just switch it with the outer pad?
also while i had the wheel off i noticed this, im not really sure what it is, i just know that it looks like it needs to be replaced so if someone could help me out and tell me what it is, thank you.
