What works (4.56)
Aimwell
Louisiana
2.9 V6
3" Body lift with lift springs on the front
31x10.50x15
Does any dana 35 ring and pinion work? Have found some that say no. 1994 Dana 35 TTB. Wanting 4.56. Any direction would be great. Thanks in advance
I'm pretty sure this was talked about here not long ago...
What I remember is there are differences between the TTB and IFS Dana 35's.
Maybe someone else will chime in...
IIRC, the TTB version is reverse rotation.
I believe that's correct. I'm running 4.56 in mine. Yukon gears. Just looked through my records but don't see the actual model number I ordered.
So I need Dana 35 TTB reverse cut 4.56 specifically?
