What transmission ?
lilbdfrd
Wilcox,NE
So I have a 84 bronco ii with a 2.8 and a 4-speed ! Do I have a tk4 transmission ? I’m in need of a shift really bad old one broke and now I’m stuck in reverse !
Ive only seen 1 aftermarket one for the TK5, no idea if itll work on a TK4.
Says its out of stock and only for a TK5.
Could try www.car-part.com
you can make a lil collet ring and ball out of delrin or nylon cutting board to get by. the tk4-5 should have same shifter.
if you pop it off you should be able to stabilize it in the pocket to change gears and move it.
