what trans mount with L&L mounts?
Ranger-Luver
can i use a solid trans mount with L&L mounts? my cross-member has rubber bushings where it mounts to the frame.
yes, i used and exploder v8 mount from the parts store, the stock mount will work 2,
the l and l are rubber so a solid trans is ok, just dont make the engine mounts and the trans mount solid, or bad things can happen
personall i would toss that crossmember out and run an 89-97 one 4 bolts solidly mouned to the frame
