What tranny to switch to
albertabronco
Red Deer, Alberta, Canada
What is needed for a Fm146 or M5od swap
ok well here is my perdicament my a4ld is toast in my 87 bronco II with the 2.9. now i want to go manual ive read that the fm146 and the m5od will both work and i should be able to keep both drive shafts the same due to the trannies being the same length is this correct?? also what all will i need to do this swap i need to knw the whole shit and cabootle thanks
Well, it should be a easy choice. If you are going to swap in a manual trans, may as well install the best that will fit. M5OD.
Read the sticky. It'll give you the rundown.
The transmissions are the same length.
same length ok so my transwer case the bw1350 will bolt on no problem as well as well i figure i need the clutch and brake pedal assembly the junk on the firewall aka slave cylinder and such all shifter and linkage. is there anything else i will need will i need the shifter boots and such due to i have the manual shift transfer case right now but with the automatic shifter??
