what the difference
Body lift, raises body up off the frame, suspension lift raises the suspension. Body lift is cheap, suspension lift usually quite a bit more expensive. As such in my opinion, suspension>body
thank nathan
I think use to lift my suspension with coil f150 89 and mod shackle
I agree with Nathan.
I'm confused though....The truck in your user profile that you claim to be yours has a V8 and a SAS with 37s yet you're asking whats the difference between a bodylift and a suspension lift? What am i missing here? :icon_confused:
I ask myself if I'm doing the same thing on my 97 ford ranger
I think he is a troll... because now that you brought "his" supposed truck up, he went and added that info to his profile... when he didn't have it before...
anyway. body lift is a cheaper way to get more clearance for tires, while suspension lift gives you more clearance for tires and ground clearance. but with a body lift you get more tire clearance so that means if you have bigger tires, you have more axle clearance too.
thank so good guy
