what the difference
Body lift, raises body up off the frame, suspension lift raises the suspension. Body lift is cheap, suspension lift usually quite a bit more expensive. As such in my opinion, suspension>body
thank nathan
I think use to lift my suspension with coil f150 89 and mod shackle
I agree with Nathan.
I'm confused though....The truck in your user profile that you claim to be yours has a V8 and a SAS with 37s yet you're asking whats the difference between a bodylift and a suspension lift? What am i missing here? :icon_confused:
I ask myself if I'm doing the same thing on my 97 ford ranger
I think he is a troll... because now that you brought "his" supposed truck up, he went and added that info to his profile... when he didn't have it before...
cursed the people judge before thoughts
anyway. body lift is a cheaper way to get more clearance for tires, while suspension lift gives you more clearance for tires and ground clearance. but with a body lift you get more tire clearance so that means if you have bigger tires, you have more axle clearance too.
thank so good guy
