What spline do i have?
suzuki14258
Ford Technician
I have a 2004 ford ranger edge, automatic, 3.0 liter, 2wd, 4.10 gears, have the 8.8 rear axle. Can i find out what spline i have without pulling the axle shafts out? Im trying to price a locker and gears but need to know which spline i have. Any help would be appriciated.
Also i have asked this before but i think i decided to go with 4.56 gears instead of 4.88s. Reason is i got 17mpg when i first got the truck with stock tires, ran the tires off a sport track ( forgot size 28 i think?) i got 24 mpg. It was the sweet spot. Now i have 33 inch tires and im geting 16.5 to 19 at the best. Mostly 17-18 mpg. Im afraid if i get 4.88s they will be low and 4.56s will put me into the sweet spot?
28 spline
and 4.56's is all you need with just 33's
Thank you, now i can price it out :-)
+1.
4.56 is good if you have a 4.0L, but the 3.0L needs more RPM to be at it's peak efficiency (2700-3000 or so). Remember the larger tires will have slightly more drag too (more rolling resistance).
Well the 33s are on the truck now and its turning 22-2300 at 65 to 70 which is WAY to low. Id like to be turning 2800 on the highway but i was afraid the 4:88s would put me like 32-3400???
4.88s would be at 2700RPM at 70MPH with 33s and an automatic...
Would 4:56 be like 24-2500 at the same speed? Just curious....
