what size rubber will fit on 16" rim
dangerranger2008
Ky
i am looking for some new tires i have 16" rims what will be the bigest size that i can put on with out any problems. i have a 3 in body lift
275/75R16 is the largest that fits on my '06 at stock height.
i have 33x11.5 and the fit perfect with no rubbing and i also have a 3" body lift
Honestly unless you want to trim chunks of body panels or lift to the point the tires will never stuff into the wheelwells during flex the biggest thing you want is the equivalent of a 33" tire. Rim offset would matter if you wanted to wider than 11.5" @ 33" as well.
