What size nut?!
Mattyd
Providence, RI
Need to know what size nut this is so I don't go spend on the wrong size and have to make 3000 trips back and forth. Its the nut holding on the hub assembly.
Thanks,
Matt
32mm deep wall socket, most parts places carry them.
Actually being technical that nut does not "Hold the hub on" it holds the CV joint in the hub
Soak it with PB blaster every 4-6 hours for a day before you kill yourself trying to get it off.
that's why i always use an impact on them:D
I tend towards 3/4" drive tools
Do coat the threads liberally with good quality never-seeze before reinstalling the nut
Also, your sway bar link is broken.
