84projectFORD
Amen. If an engine is out, has a bit of miles, and doesn't smoke I'd drop a crank kit in it (assuming it's possible to do on the particular engine without removing the pistons. $200 or less for good crank clearances while the engine is already out is a good deal IMO.
ok well im not guna go that deep. at that point i might as well rebuild the whole motor. ill do almost all the seals and gaskets (not doin the head gaskets but will check to make sure the head bolts are tight) but should the motor decide to let go internally then so be it, ill just go buy a lower milage motor at that point or build that one into a 300-400 hp motor if the block didnt break.
at this point i just ordered: rockers, push rods, clutch, flywheel, plugs and wires, thermostat, waterpump, oil filter, belt, idler pully, and a engine seal gasket kit. $560 bucks, i love having a discount at NAPA
