What RPM's does an ARLD Ranger Run?
mkRanger
I just bought an 88 Ford Ranger with an 2.9/Auto. What kind of RPM's does your Rangers run going down the road. I'm beginning to learn the tranny's aren't good. Mine turns 3200 at 70 mph. Is that normal? Thanks, Matt
it all depends on the gearing. mine turns 4k with 31x10.50 and 4.10 gears but my overdrive doesn't work and thats at around 60
It depends on the gearing but that sounds about right in drive, not OD.
OD would be around 2300 to 2400 or so.
mine WAS doing about that... now its up closer to 4000:icon_surprised: allthough i brought it into a shop and they said every seemed fine
also 3000 is right about my trucks sweet spot, i found that i get better mileage around there. again all trucks are different though
You should be moving pretty decently @ 4K in O/D (90mph?). :) I would suggest something, but the only thing I know about autos is to replace them when they go out. I hope they didn't charge you for looking at it...
I think the last time I actually was in O/D I was turning ~2,700 @ 70mph. Need to take it out on the highway soon...
Pete
Everyone has it right. Sounds like you're missing O/D. Mine will turn 3000 rpm in Drive @100kph (60 mph) with 31" rubber.
mine would run about 3200-3500 rpms at about 75. stock 2.9 with 4.10s with
235/75/15s
