92ranger18
im swaping a 302 in my ranger ang im using the radiator out or a 4.0l explorer. What vehicle can i get radiator hoses off of that will work?
ok thanks and another question what kind of alternators are you guys runnin ive got one off a 1989 F150 will that work if i get the connector off the truck for the alt?
i dont remember what works best with that particular situation you have. i assume you have the radiator in the stock location. like mentioned trial fit with wire shouldnt take too long if you are willing to splice....a big variance is the water neck/t-stat housing one chooses to use.
i prefer to use a bigger radiator and modify the core support/upper frame rails to fit it. simply to maximize cooling potential and space. the 25ish x 19ish ford type radiators from summit work well. its nice to be able to swap a water pump in 1/2 hour too.
the moroso type inline rad cap fitting, spliced into a mustang upper works good, with a 80,s f series lower modifed a bit work well with the summit radiator.
I am using a stock V8 Explorer upper rad hose and a stock lower rad hose for a 97 Ranger 4L V6. No custom hoses for me and they fit like factory on mine. Oh yea I am using a 97 Ranger HD 4L rad in my 94 Ranger. This is the only pic that I can find right now that showes the rad hose.
