Hoofhearted
- Jul 5, 2014
- Automatic
Greetings Fordlings,
I understand this is probably a technical issue, and may not be a question for Ranger owners, but I'll go ahead and shoot.
Last summer, my AC worked fine- no problems.
Next spring, it no longer blew cold air.
I took the Ranger in to have some repairs and maintenance done on the front end, told them to take a look at the ac too.
I gave them permission to charge it up if that's all it needed, but to not do any extensive repairs without first consulting me.
I now understand, it was ignorance on my part that lead me to believe a simple charging of the unit might fix the problem... but I digress.
They called and said front end was done, but that I would need a new compressor- at which they quoted me in excess of $600 to complete the install.
I kindly told them No Thanks, and never thought to ask, "How" they were able to come to their prognosis of a bad compressor.
I'm just wondering if perhaps the AC stopped working due to a leak which had formed at some time after the end of last summer.
If this is the case, it seems the compressor would have a safety switch to prevent it from kicking on.
I understand that sometimes, things just crap out, but there often is a simpler explanation.
I don't distrust the shop that worked on it, but I would not be shocked to learn it was an error on their part- either misdiagnosing, or perhaps even causing the damage themselves by use of improper technique.
Does anyone have any thoughts or experience with these compressors,,and Are they prone to failure and replacement?
Hoping to gain a bit of insight here.
Thanks!
'02 Ranger 4.0
Thanks!
'02 Ranger 4.0
