what kind of speedometer do i get?
fordtrucks4toys
hawaii
i got a 83 ranger 4x4. 2.8 v6, manual trans.
the speedo cable broke during my body swap.the gauges are broke, so im using all aftermarket gauges. what after market speedometer do i need to get?
the sticker on my trans says E37A 7003PA buld code 006305, i think its a newer trans in the truck??
but what speedo do i need to get, i got one a while back and the worm gear was different. any help would be freaking awesome!!!
thanks !
most aftermarket speedos use the same generic drive, i had a similar situation about 4 years ago i had a dolphin instruments mechanical speedo on my 85 ranger and the stock cable slid right onto the speed and i just put a hose clamp on it to keep it from pulling off. i did however have to change the little plastic gear on the speedo drive in the trans and it was within about 3 mph of being correct. hope this helps some.
