kenwheeler
I'm a step or two below "backyard mechanic" I want to replace some parts I should've replaced when I installed a new clutch last month but my Haynes manual isn't very good with the pictures and descriptions.
1. Whats the little bearing called that goes inside the flywheel?
2. Is the throwout bearing the plastic thing that rides on the shaft between the pressure plate fingers and the big spring in front of the slave cylinder?
