takopolicia
I need to know what the heck this thing is and if I can make a block-off plate for it.
Thank you! Do you have any recommendations for a bigger one? aftermarket?That is the oil separator for the PCV system, I would not recommend blocking it off, if anything it needs a bigger one...
thank you!block it off and youl could blow seals, thats how the crankcase breathes. the pcv valve fits into the top of it, air is drawn into the engine by that hose on top of cam cover that goes to the throttle body.
thank you man!I also helps keep oil vapor out of your intake. Not as good as a good catch can system but better than what most engines have.
