What is this?
lukelou
SA, TX
Does anyone know what this is a picture of? Or what it is called? where i can find a new one? Please Help i have no clue what it is! Click attachment plz!
That is the canister that goes between the block and the PCV...I just call it a PCV canister and the best place to find one is from a junkyard...you may be able to use one from any number of 2.3 engines, but it has to clear the intake manifold...some are a bit taller and certain engines with certain intakes can only take certain sizes...
It is actually identical to the one I have on my 88 but I'm not sure where I got mine...I know I replaced it with an identical one probably from an 87 or 88 Ranger. But the Mustangs and Rangers used the same type of setup...you might want to grab the hose too if you can find a complete unit...
But if you have one and can't find another you may be able to use the one you have...unless it is damaged...if it is plugged just soak it in some gasoline for an hour or so and scrape it out with a screwdriver or some other...not hard to clean them.
