1 wire means it is a "sender" not a sensor, it uses the engine as the Ground, so it is for a dash board gauge, not computer.
From it's location it would be the temp sender, other sender is the oil pressure sender, and I believe oil level is also uses a sender if so equipped.
What engine is it?
ECT(engine coolant temp) Sensor has 2 wires and is usually located near the temp sender, as they need the same information......coolant temp, this one is only used by the computer.
EVAP(fuel tank pressure) codes can take a long time to clear, keep fuel level in tank between 1/4 and 3/4, so don't drive to empty and don't full up, for a few weeks, PITA but it helps.
