Take a non-powered test light and run it between the battery positive and the green wire at the ignition coil. It should flash with the engine cranking.
If it does, check for key-on power on the other wire. If it doesn't check for key on power to the TFI module.
If you actually sit down and diagnose instead of throwing parts at it you can probably fix this for under $100. A few years ago I bought a real clean truck for cheap because the guy couldn't make it run. I hauled it home, spent one hour testing things, $20 on parts, and have driven that engine and wiring in a different vehicle for almost 20K miles, used the body for a different project.
