Rodney
- Mar 9, 2008
I pulled my distributor out about a month ago in order to replace my heads on a 2.9L engine and can't remember the exact position of the rotor when it is on #1 TDC. I know you basically make sure it's lined up with the spark plug wire position on the distributor cap however when I dropped the distributor in it seemed to be a little to far to the left of #1 and when I tried again, it seemed to far to the right of #1. I made sure I only rotated the rotor a small amount when dropping the distributor back in but there seems to be a big difference in position between one tooth and the other. Is this true or 'am I just not getting it right? What clock position should the rotor be at when pointing to #1, 10? 11? Also when I started the truck up after reassembling everything it ran like crap, would not idle and basically seemed like it was running way out of time. No matter how much I adjusted the distributor housing it did not improve. Would appreciate some advice.
