Kirby,
If you haven't spent any money yet, there are 4 options to consider with your Ford 4.0L ohv 98 spec block:
A) 94 pistons/94 heads, no change
B) 98 pistons/97 heads, no change
C) 98 pistons/98 heads, only if you are having Flow bench port/polish performed, as the exhaust ports are reduced size
D) 01 SOHC 4.0L flat top pistons/94 heads +8 hps from compression increase (3-6%); this is what I chose to do, 3-6% power/torque/fuel economy for free, I'm signed up in advance!!
Also, if you decide to use the quality products Smith Brother's offers, consider the small increased expense of having the custom push rods set be adjustable. This will insure that you are able to maintain the highest possible performance from this engine's valve train until it needs a rebuild.
For an improved rocker arm set, contact Delta Camshaft of Tacoma Washington; they are the only company left on the planet that sells the hardened rocker sets.
A quality multi angle valve job will also be money WELL SPENT, vs using them as is.
