Buggyman
- Dec 1, 2007
I just dropped a 2000 3.0 into my 1998 Ranger that just blew its motor that was also a 3.0. I attached all the electrical connections back the same way they went with one exception... The wiring harness that leads to the starter and alternator was in rough shape on my donor motor and I jacked the harness off my old motor that was in good shape and attached it. I also put a new starter on the motor and had a hard time getting the wires attached without crossing. I finally got everything wired up and have no shorts on the starter, when I turn the key, the fuel pump comes on, dash lights up and then I go to turn the motor over and then there is a loud snap under the hood and everything goes dead. Sometimes the radio will stay on AFTER I have removed the key, which it used to never do before. Any ideas? I have spent the entire day reattaching the wires on the starter in every possible way to make sure they are tight and not touching. The alternator looks fine.
Thanks for any pointers....
Philip
Philip
