what driveshaft for 6" lift?
bigfltruck
i have a 89 bronco2 im fixn to lift 6". it has a 2.9 v6, with a 5 speed trans, manual 1350 transfercase and stock axles. i want to know if there is a drive shaft that i can use for the rear that will just bolt in so i dont have to drop $$$ at the shaft shop. thanks for eney help.
I used the stock driveshaft out of an '84 Bronco II (had a C5) in my '87 with an A4LD. I cut the CV part off because it would have been too long. I would think that you should almost be able to use the one that came with it - mine was the shitty GKN type with two CVs - and it fit, but it was really worn out so that is why I swapped.
Find a 1354, remove the front yoke, install front yoke on the rear of your 1350 and install the front driveshaft from an explorer on the rear of your b2.
