what does driver side blinker wire connect too?
swynx
lewiston idaho
Blinker has been rewired in the past. Noticed it wasn't working. Traced the wire it end under the hood. It connects to the fuse panel? In the cab, either that or a blinker relay I'd assume.. Sorry I'm not very good at wiring issues. don't have my Haynes manual at the moment and yes the front blinker works
Driver side rear was rewired but the wire just comes to an end under the hood. The drivers front works.i don't know where the blinker relay is at. I was gonna trace the passenger rear blinker and see where it ends up. But the front blinkers work.
If someone ran a new wire from the back blinker they probably ran it to the front blinker.
There is no "relay", just a 15a fuse and the flasher, all turn signal wires terminate at the steering column, and are there connected to the "Multifunction switch" harness, the arm that activates the turn signals and wipers.
If you look at the wiring diagram you can see what colors the wires are and then try to find the original problem, I would guess someone was trying to wire up trailer lights and F-ed up the wires.
This is a good tech sheet on trailer light wiring, with color codes
http://www.therangerstation.com/tech_library/TrailerLights.html
