Actually the issue with spinning the 4.0OHV faster is a "Bob weight" and harmonic balance issue.
A V engine of any number of cylinders cannot be be perfectly balanced at ALL rpms
The Cologne engine family is semi-amous for the "cologne drone" the annoying harmonic
vibration the engine is subject to...
the 2.9 engine vibrated at 2900-3100rpm peaking just below 3000rpm.
the 4.0 with it's longer stroke vibrates somewhat lower
The point being that somewhere above 5300rpm a 4.0OHV is going to try REAL HARD to shake that crank right out of the block...
IF OTOH you were to build your 4.0OHV around a mid1997-up
rotating assembly (easily identified by the EIGHT crankshaft to
flywheel bolts) aka the "lightweight" rotating assembly the bottom \
end is "Safe" (harmonically) to over 6200rpm.
frankly there was no point in making the early 4.0 capable of spinning
past the mid 4000range because the engine had a power peak of 4200rpm
a redline of 4500rpm and were often rev limited to 4650rpm
(Would anyone be suprised that on a 1993-ish 4.0 that's how I check
tach calibration?)
The 4.0 engine is designed and built to produce torque way down low.
IT does it REAL well.
Trying to turn it into a revver? it's like training an Ox to run in the
Kentucky Derby.
A)It's a waste of time (even considering it)
B)It greatly annoys the Ox.
If you are unhappy with what a 4.0-OHV can deliver
don't waste time modifying it, replace it
But when you are considering replacements consider what you are going to use your truck for. and WHY you want "more" and what exactly "More" really is...
AD
