That is a big boy.
I’m still a little confused on why you guys use the hoists to move the beds around. I’ve moved four or five of them around, and all I ever did was pick them up from one side and slide them over the other side, or slide them back, and step in the frame, and stand them up behind the truck. None of these were pristine, and you know I paint them with Rustoleum, but they never got damaged. The two that I was trying to be careful with, I just put moving blankets on the ground and slid it onto that. Then I just walked it where I needed it by rocking side to side fairly gently. And the one I put back on, that I didn’t want to scratch, I did the same thing in reverse with the moving blankets. Then I laid under the truck, and pushed the bed up with one hand or one leg and slid the blankets out. Am I missing something?
And I just had a dangerous bad idea for your lift. You can pick up fitness weights all the time on craigslist for nothing or a couple dollars. You could cut pieces of pipe and make stands on the backside, and weight that down to help with the tip over problem. Then all you’d have to worry about is the thing folding up like a scissor on your head.
I'll pass on the extra weights, they work better on tractors anyway.
the bulging disks in my spine highly recommend using tools. one of the few times I listen to good advise.
