- Aug 6, 2007
- State - Country
- GA - USA
- Vehicle
- Ford Ranger
- Automatic
- Total Drop
- few inches
- Tire Size
- ~30"
If you keep going like that you won;t have any of your fleet usable. LOLWell, this afternoon I decided that I’m tired of the poor light output with the headlights in the Choptop and since I have an upgrade harness, I figured I’d throw it in with some new bulbs right quick…
Yeah…
The engine bay is pretty tore apart now. Apparently my radiator is leaking and since I pulled the airbox in an effort not to have to pull the battery but just shift it back a little (that didn’t work, the battery is now out too), I figured I’d try to address why I don’t have good airflow through the heat ducts and here we are. Oh, and I don’t have the headlight harness in yet, lol
I know the feeling. That's why I'm trying to work one task at a time to completion. Currently the old '95 Kawasaki Bayou 300 4x4. Similar situation. Trying to get it to run, eventually does with a shot of ether and getting fresh gas into it. Acts like fuel starvation and not getting fuel to carb. Acquire stuff to check float level adjustment, and definitely not getting fuel to carb. Seems to be float valve pull carb float needle is stuck, clean and fix that, then level is low, carb on and off several times, and figure out needle still keeps sticking. Amazon aftermarket carb installed, find the original that dad fortunately saved sitting on the shelf. Ordered rebuild kit for new seals and float needle, disassembled carb and proceeded to run it in ultrasonic for about a half hour. Works better than expected, and that was with the cheap ultrasonic, I'm sure a good one would do even better.
During that discover that petcock is bad, flow fuel fine, but won't completely shut it off. Removed tank to remove and inspect petcock, lot of stuff rattling around in tank. Inside of tank is clean, but I discovered that the fuel level gauge has fallen apart inside. Yay, I get to take a gas bath while trying to fish gauge parts out of tank, BTDT with a lot worse fuel (JP8 and/or purging fluid), but it still isn't fun. I'll worry about a new gauge after I get the engine sorted, or not at all. Rubber disc inside of petcock has deteriorated can;t be fixed without a new packing, and it's an aftermarket replacement so who knows if factory part will fit. Ordered another new aftermarket petcock, it's close to the same price as the packing disc and needed new fuel strainers anyway.
Today...
Parts arrived, got petcock installed and that is one problem fixed.
Got the carb reassembled with new seals, but reusing the original jets. (I assume, they were the ones in that carb) Set adjustments per repair manual. It'll start and idle from cold without choke now, weather was high 70s at the time. Unfortunately if I apply throttle or choke, it immediately dies. Applying throttle still kind of acted like it was running out of fuel. Used contraption to check fuel level again, still low, but better than before rebuild and new petcock. Harb has to beinstalled to check level, but removed to adjust it. Engine was too warm to go sticking my hands in there to remove it. Also sounds like it could be pilot jet needle, and that unfortunately also requires carburetor come off to access, or at least a cool engine and a very small stubby screwdriver. Looks like I'll be on and off with the carb a few times trying to get it right.
Unfortunately this is a slow process, It's already been over the course of about two weeks, because it isn't at my house and I have to wait for parts to arrive. Pressed pause on getting the F-250 ready to move on because this ATV was one of dad's projects and need to get it running so it is easier to move around, to clear out the shop, and so that someone can actually ride it and keep it running. It's in this condition now because it didn't get ridden nearly enough. Hopefully I can convince my sister and borther-in-law to ake and ride it and dad's newer atv some, cause I can't keep all three of them going by myself. That said, I'll probabvly put it on pause for the rest of this week and focus on the F-250, need to get it moved along before I'm tempted to do more to it.
Doesn't sound like much between the two, but there's more on the backburner. The cam position sensor DTC on the '99 Ranger, and itr really wantss some transmission attention. The '10 Kia needs either brake work or wheel bearing in the front. The '85 Ranger needs everything, I'm really not thinking about it right now. The F-100 hasn't been run but maybe once this year, the weather is getting right for it (no AC), but I just don't have time. Fortunately I've got dad's F-150, the '99 is still drivable with that pesky CEL, and the Kia can be driven with the radio turned up enough to cover the brake/bearing noise.
