Got further on the '90, got a preliminary alignment done, installed drivers side shock, the other shock I bought was leaking in the package so I'll get with the manufacturer tomorrow... I packed and installed the new bearings and such on the drivers side then stripped the passenger side to change the axle seal on that side of the diff then got that reassembled... next step is to put the coils back in then the tires. I'll put the shock in later once I figure that out. After I get it on tires again I need to drill holes for the other 4 bolts for the radius arm brackets...
Picked up mint cab and fenders
Yesterday I picked up an axle shaft seal, took 3 stores to find one... then put stuff together. Ended up putting the old shock that still had pressure on the passenger side, got the tires on and it on the ground! Got some of the cleanup done on the thing, there were tools and stuff everywhere! Still some left to do and drilling those 4 holes then it'll be time for a test drive...
My drivers outside door handle was getting loose so I pulled the door apart yesterday to see what was going on. The truck has no outside door lock cylinder on the passenger side so If the drivers door won't open and the passenger door is locked, I'd be screwed. No surprise with 170,000 on the body, the door handle pivots were worn out and loose. My son went online and found a new Dorman outside door handle in stock at Advance, 15 miles away and open on Sunday. Bonus. I figured I'd have to order one and wait.
Well... been busy last month or so. Moving to a new house has me putting more miles on my Ranger in the last month than the entire 2 years prior.
Closed on the new house June 3, pulled into the drive, unloaded the pos lawnmower, grill and few other miscellaneous stuff, went to the storage shed and got another load. Unloaded and put the Ranger in the garage (first time in over a decade) noticed the next day a fairly sizeable puddle of oil or transmission fluid on the floor underneath it. Thinking Trans lines as it was more on the passenger side. Driving and shifting great. Checked the oil, down a bit. Parked it on the street for a week, oil is down to the bottom of the cross hatch on the dipstick and a 2 foot by 3 foot puddle under it. Put oil in and went to lowes to pick up some stuff including a water heater catch pan to throw under it so I wouldn't ruin my driveway.
Dealt with it by adding oil until today and finally got under it..
Got a good coat of oil on the oilpan. Was thinking rear main seal... then I saw a dent on the oil filter.. could it be that easy?
And yes, it was that easy. 40 bucks for a new Motorcraft filter and 5qt of oil and the Ranger is no longer incontinent.
Have no clue how the filter got whacked, it is fairly recessed and protected, I couldn't see the filter unless I was almost right under it. My guess is I kicked up a rock in chunk of metal and it bounced off the road into the filter. Glad it wasn't the oil or transmission pan.
AJ
Tonight I drilled the 4 holes left and installed the bolts then took a couple hot laps around the yard, the front suspension works WAY better, can definitely hit stuff harder without hearing the inner fenders on the tires! At full stuff and turning I think the front of the inner fender is touching now annoyingly though, might have pushed the front axle a little too far, I should be able to weasel that forward though, it's not near as hard as the firewall!
Went down the road, alignment isn't dialed, can hear tire noise which I shouldn't be able to but the wheel is straight! I think I have too much toe in, will verify in a couple days, I parked in a way I can measure it where it is...
All in all a win! I'd post pictures but I'm beat, I'll work on it...
decided we are to the point that the ranger needs a new clutch. the pedal is half an inch off the floor and loses grip when backing the trailer in reverse.
yay :(
I used a 4 mm socket and quarter inch drive ratchet with a ratchet handle extension* to adjust one headlight that was running high.
* f/k/a paint stick, f/k/a D molding with vinyl tape
Dropped off more parts at the machine shop. Realized over the weekend that since I'h having to bore and replace pistons, it probably needs to be rebalanced. Dropped off the balancer and flex plate. I'm really getting tirted of waiting though. I said when I dropped it off that I wasn't in a rush. That was May 6th. At the time the block was clean, engine appeared to be all original and never opened, was running in March and disassembled the day before. It appeared to need only a cleaning, inspection, and hone. So I said no rush under the impression that once they got to it, quoted 3-4 weeks lead, it would be done in a week or two. During week 5 they finally got to it and decided that it needed a dip in Evaporust to remove some cylinder rust. (Where did that come from?) Week 6 they recommended an overbore to clean up pitting (again, where from?), and I dropped off the new pistons last Wednesday after a trip to Summit. Near as I can tell my block still isn't bored, and now we've added balancing to the list of work.
I was hoping to have the bottom end being assembled right now. Starting to go in first part of next month. Running by the middle of July and then through September to functional test before the Anniversary Gathering.
Now I don't know when I'm going to get the block back. Starting to hit high 90s and 100s which is really going to slow down work. It's not looking promising to have things ironed out before September.
I might have chanced it with the existing engine, but I started doing some suspension maintenance and hit a snag. A snag which needs the engine pulled to fix, and that isn;t happening until it's ready to swap over. Because I started the alignbment is screwed, and I'm not going to get it done until the snag is fixed. So basically the truck is unservicable until I get a block back. No Ranger, no go trip to LBL.
I'll quit my bitcin now, just needed to vent.
I finally pulled the camper shell off my 2008. I've been on the fence about it for a while but I prefer the real pickup feel of a Ranger.
Not sure what to do with it now. 🤷
Do you think you might want to reinstall and use it occasionally? Do you have the option of modifying the garage?
If I had the place (AKA: a garage/carport) and a caper shell that I wanted to use occasionally but not have perminently installed. I'd rig up a system to lift and store the topper hanging from the ceiling.
since the VIN is permanently affixed to the cab, you now have a different truck.
check the regs, stay out of legal trouble.
Might not matter to him. For some people maintaining the same VIN matters, for others it doesn't. I'm not going to suggest something so shady and illegal as swapping vin tags. If maintaining the VIN doesn't matter much, then the cab is just replacable sheetmetal. It's old enough that in most areas that cab is transferable on a bill of sale. Swap the cab over, carry the BoS to the DMV, and register truck using the new VIN.
With my 84 the VIN mattered, but if swapping cab and registering the new VIN could have kept it on the road, I'd have swapped. Unfortunately it was so damaged in the wreck that it is not saveable. The hood is probably the only straight part left (if it is), maybe the driver door, fender, and floor panel (hoping it might be salvageable for the 85).
For my 85, I don't care as much, but it's kind of unique. Not saying its a 1-of-1, but pretty high optioned, so I'd like to maintain the original cab and VIN.
Put a new stereo in it. Just a single DIN Pioneer. My requirements were; Bluetooth capable, front aux in port, front usb port and, preferably non-removable faceplate. Well, it has a removable faceplate. Anyway. Now I have hands-free phone capability and my tablet can connect and interrupt the music to give me navigation instructions and I can connect my Sirius/XM receiver dock and use my thumb drive with music on it. My new door speakers were supposed to arrive today, also. But they didn't. The old ones sound like the cones are damaged.
Sorry. No pictures. It's mostly hidden behind the tablet mounting bracket anyway.
Ordered up a set of sway bar links, installed a pro-fit VSM bracket, and ordered a light controller that will live on said bracket.
Yup, I'm gearing up for bumpers and lights.
Ok, here's some pics from the last few days. First is what I ended up doing for my preliminary alignment that I'll likely just leave, I checked the toe tonight and it's even somehow... Anyway I just took a HFT magnet bar and stuck it to two lugs on each side and put some nuts on the outside to hold them tight to the hubs...
Next is just after I got it sitting on all 4 tires again, still had to drill the 4 extra holes in the radius arm brackets and frame. Then the next two are on my burm on the first test drive
Event Coverage
TRS Merch
