What can I substitute in place of a pickle fork?
a bfh and a wood block...
what are you trying to do anyways?
Take off my front ball joints. I need to replace them, but I don't want to buy a tool I'll use maybe once or twice in the next 10 years..
See if you can rent one locally. A cheapy isn't going to cost more than 15 bucks. I think I paid $13 for mine from Advance Auto Parts, and I've beaten the shit out of it.
Pete
Pete
I'm on an extremely tight budget. I decided to keep the truck instead of selling it and now I have to fix everything that's wrong with it, or else my license goes bye bye.
I'll see what I can do with some of the suggestions posted.
Dude tell your girl you want one for christmas...
You can get a Pitman arm puller for $8 and a C-frame press for $30, from Harbor Freight Ask your family for them for Christmas. A balljoint replacement without them is VERY painful, and with them, is not so bad.
If you have an Advance Auto or Autozone nearby, you can borrow a ball joint tool for free.
Basically they'll charge your credit card the full price of the tool(in case someone "forgets" to bring it back) and then issue you a full refund when you return it.
The local stores here loan out for 30 days max. After 30 days, you own it.
To separate the knuckle from the beam, I always use a BFH. In my case its a 4lb "Engineers Hammer"
Get a the balljoint tool from the autoparts store. Its free when you return it.
When your using it, make sure to apply a little grease to the threads of the drive screw. It will make life much easier.
for the upper balljoint, remove the pinch bolt and hammer a large screwdriver or prybar into the seam to help widen the pinch seam a little. then tap the ball joint shaft with a hammer.
for the bottom, remove the bolt from the ball joint, then thread it back on a few turns (gives you a larger target and keeps the knuckle from falling on your foot once the balljoint pops loose) and wail on it with a hammer.
Yep, all you need is a big hammer. Once I got the knuckle free from the beam (using a hammer), I put the knuckle in a large vice and beat the ball joints out with the hammer. It would have taken me longer to set the c-clamp ball joint press up than it did to beat them out.
Also don't use a pickle fork. You risk destroying the knuckle, beam, or camber bushing that you're prying against.
I don't understand why people dread doing ball joints so much...I've done them a lot of times and I always have fun doing it...although without the proper tools I would imagine its a bitch.
