what camber bushings to get with lift
juggalomania92
Richmond, Rhode Island
i have a 4inch lift kit with drop brackets, drop pitman arm, coils etc, and i wanna know what "alignment" kit i should get, and also can i run the coils with a 2inch spacer or would i need to get 6inch drop brackets to do that?
Yes you can generally fit the coil spacers in with the 4 inch drop brackets. An usually I just install the lift then have it checked by sears who tells me the can't allign it but tells me how much I'm off then I buy the right camber bushings at napa and do it myself.
To do it correctly, you have to know what the current adjustment of your frontend is (or have some reference of what is needed) before you go buy bushings for it, otherwise there's a high probability you won't be able to dial in your camber while maintaining correct caster (and vice-versa).
The only exception to this is if you use the fully-adjustable two-piece bushings (Ingalls 59400, Moog K8986, Spicer/Raybestos #6122025, etc.). These you can dial to any degree amount needed without having to replace the whole bushing (and are handy to have should you need to make adjustments in the future).
As for the spacers, if your truck is a Supercab, chances are good you can use them without a problem.
alright sweet thanks for the answers on that, and yeah my truck is a supercab, i realized one thing though, what shocks should i get for the rear of the truck with the lit?
