what cabs will bolt on s 83 frame
mikeweth
I have a 1983 ranger and i am thinking about swaping cabs due to rust. And i wanted to know if newer cabs will bolt on.... or the amount of work needed to put a newer cab on.
83-92 regular cab. Dash swap required for 1986 and later.
93 and 94 might. 96 or 97 saw some changes. In 93 the body lines changed a lot, the wiring changed and it is harder to put the early dash in them.
It can be done, but if you have to ask I assume you want easy.
well its my mud truck so there isnt much wiring i was just wondering if the body bolts would line up with the frame
