99_3.0
I have a few questions about using my new $130 dollar (WOOOHOO) welder effectively. It's a Northern Tool 125, 110 volt flux cored wire feed. It has the ability to run .030 or .035. I've been using the .030 that came with it and have had pretty good results. It will penetrate 1/8th inch steel well with a couple passes. Would .030 or .035 be the most effective in welding thicker stuff? I have NO need to weld thin sheet metal junk. All use of this welder is 1/8th inch or 3/16ths. Which brands of wire are the best? Any and all advice is appreciated!
