79machowagon
if i weld the spider gears up on a limited slip rear will it work or still slip, i ask a lot of ppl i know and i got both yes and no answers i am not sure
No, welding the spider gears is the same as installing a full time locker, they won't slip at all. limited slip is just fine, you don't need to weld them they will spin both tires under enough torque.
Limited slips are glorified open diffs.
A GOOD and TIGHTLY packed limited slip HELPS but is no replacement for a locker/spool/welded diff.
86
86
