Mark_88
- Aug 11, 2007
- Age
- 69
- Ontario, Canada
- Automatic
- My credo
- Love Thy Neighbor
I've been getting a bit better gas mileage lately since fixing the vac leak, but decided yesterday to try to tweak the carb a bit...wasn't too successful and ended up just putting it back to where I thought it should be...
Today I drive (limp) down the highway and it was bucking, lugging and just about anything but run decent...I farted around a bit more with it and decided to head home to check the timing...along the way it suddenly starts running right...
I was thinking this was maybe either bad gas, a vac leak (that I happened to notice the PCV cannister was loose and even after pushing it down it still acted up), or maybe fuel filter on the carb was plugged...
Any thoughts?
Nothing I did seemed to correct it instantly, but pushing it (as in accelerator to the floor) down the highway eventually got it sorted out...only thing out of sorts that I noticed was the gas guage dropped from half a tank to an eighth in about 20 kms...but then it sprang back up to about a quarter tank...put about $20 worth of gas in and it now shows almost full...
Shorting wire? bad gas? dirty filter?
Any thoughts?
