weird stuff going on now
90range
SL,UT
ok so after getting all the wiring figured out, i was out driving the truck when all of a sudden the throttle just quit working, and now the check engine light only comes on when the truck is in gear but turns of when you put in neutral, it has the five speed trans, the tps is good, and the throttle cable is nice and tight so any ideas
sweet thanks for the info on the throttle, turns out the valve did get stuck, took it off cleaned it up a bit all is going good with that:icon_cheers:, now just need to figure out the crazy check engine light
