MAKG
- Aug 7, 2007
OK, I just bought a 1990 Jetta since my wife accordioned the Prizm (293K, RIP).
What an FN weird car.
The thermostat is on the radiator OUTLET conveniently located under the power steering pump bracket on the bottom of the engine. Held in by an ear the oil pan and TWO BLIND BOLTS. And the thermostat that came out of it was clearly stuck open and stamped "Made in W. Germany," i.e., factory original equipment (build date was almost exactly when West Germany ceased to exist).
There is no radiator cap. The overflow is pressurized and that's the only way to fill it.
There is a PCM, but no self tests, no diagnostic port, and no check engine light (though there would be if it was CA emissions -- this thing appears to have been bought in Germany and has a Federal emissions sticker). It has a VAF, which absolutely everyone seems to call a MAF (no, they are VERY different). It's just a spring-loaded flap in the throttle body, connected to a rheostat much like a TPS. I know VW basically invented EFI (along with Bosch), but even GM figured out self tests were essential in 1978 (in the Cadillac 350s). Ford EEC-IV did it in 1983. It's a basic tenet of control theory....
The reverse gear is "0th" instead of "6th." While that might sound like a good idea to keep from "shifting to 6th" on the highway, it's actually VERY easy to think you're in reverse when you're really in 1st. Not good in a parking lot.
The "dinger" yells at you if you leave the key in the ignition, but not if you leave the headlights on. And the car automatically turns the headlights off for you, but NOT the parking lights (so you can still drain the battery).
The turn signal indicator doesn't tell you what direction you're signalling!
OK, that's enough ranting for now. I still have to smog sniff this thing, and I'd really like to run the self tests. If there were any....
