85_Ranger4x4
Wallows in rivers
TRS Event Staff
OTOTM Winner
I have fought sealing this thing from day one two years ago. After initial install had an air leak which caused a ping under a load and would dribble coolant out so it would pool on top the timing cover. I ripped it off, changed the heads to E7's and reinstalled it carefully last summer. The air leak went away but coolant still dribbled on top of the timing cover so it always smelled of hot antifreeze. Never gets coolant in the oil just on the top of the timing cover.
I pressurized the system cold sabout a month ago and sure enough it was just creaping out of the intake between the intake and head and rolling down the silicone on the front of the valley and running down into the pockets on the top of the timing cover area.
I finally got free time that lined up with decent (perfect at the moment actually) weather and ripped the intake off again last night. Since I am getting kind of tired of this I go over it with a fine tooth comb and notice that it seems the intake wasn't sitting square on the engine. The top side of one gasket was crushed and the bottom side of the other gasket was crushed. I followed Weiand's direction both times...
One thing that I noticed as soon as I took the thing out of the box is the contoured edge of the intake rolls down to the endge of the bolt holes so the bolt cannot bear evenly on the intake manifold. IMO if both sides are not tighted at exactly the same time it would be really easy for the first bolt to roll the intake to that side as it is tightened right? Anyone else heard of this?
I have pics but as usual since the big update photobucket is being stupid...
